- Windsor, CO NEC: 2023
- Hospital Master Electrician
1.) NEC Section/Paragraph: Figure 210.52
2.) Proposal Recommends: deleted text
3.) Proposal: Delete the term indicated from Figure 210.52:
I would type the term in, but the site is perceiving it as instructions!
4.) Substantiation: This figure is a good addition to the 2005. However, in practice, when a kitchen sink is placed the the corner of a kitchen, it is frequently flanked by windows. Just as frequently, the corner of the space lies just outside of 18" from the sink. This places an undue burden on the installer to not compromise the structure by cutting a receptacle outlet into load bearing corners or bearing studs surrounding windows.
In addition, the receptacle required is usually not readily accessible to most medium-height adults; a typical countertop is around 36" tall, and 24" deep. In the corners, this distance can increase dramatically, precluding the likelihood that such a receptacle outlet would ever be used for small appliances with 2' cords, behind a sink.
I am 6' 1", and I nearly have to get on the counter to touch kitchen corners that barely fall under this requirement.
