A customer bought some equipment with a 460v motor. It's able to be converted to 230v but the diagram and nameplate a little hard to read. The nameplate looks like it says .83-5 after the HP. It says Volts 44-230/88-460. I'm a little confused by the 44 and 88 and also the .83 (if that's what it actually says) on the nameplate. Anyone know what they mean? The Amps label says 13.5/6.75.
The real question I have though is this. I rewired it for 230 volts as best I could given the diagram that was somewhat deteriorated. I think it looked like I was to just pull the wire numbers 4,5, and 6 out of the wire nuts where they were tied together with (I think) 7, 8, and 9 and I think that's what I did and then just capped 4, 5, and 6. I looked online and saw someone posted that to rewire this for the low voltage side it should go like this:
1 and 7 together to L1
2 and 8 together to L2
3 and 9 together to L3
and 4, 5, and 6 tied together.
I don't think I tied 4, 5, and 6 together. I think I just capped them. Today, I started the motor and the current draw was around 40 amps. My question is this. If I didn't tie the 4, 5, and 6 wires together would the motor still run and would that cause it to draw roughly 3 times the current...?
