boboelectric
- Eighty Four,Pa.15330
We don't scab hookups out of respect to the linemen's union,which they always want to pare.
I used to lay them on the ground and wire nut a GFCI recep for working power.
The last time I did it, the messenger wire came into contact with the fuse link of the pole mounted transformer.
I won't be doing that again.
POCO generally ties them off but this lineman just let it drop.
We do the work hot and deal with the permits, paperwork, inspections later on when it's convenient.
Cal-OSHA does not keep workers safe, the workers' brains keep them safe. I haven't lost a worker to death in several days so I gues we're doin' OK so far this week.
We use the set-screw type butt splices.
i don't even like to move an old drop around much.... 40 year old triplex
can be brittle, and if it grounds on the messenger cable, it'll fuse it, drop
to the ground, and relay the pole fuses..... then you have ten houses dead,
and an outage.
being the center of attention is ok sometimes. this isn't one of those times.
randy
