wireguy8169
- Southern Maine
Here is what we have.....We are retro fitting approx. 10 pole lights we are removing HPS heads and installing LED heads. While doing the work we found that the feed to the first pole is damaged and unusable, as well there was an issue previously that during some plan upgrades some conduits were hit while digging one being to the first pole. The previous maintenance person ran UF to the pole to fix the issue. Now we have an issue as I said with the UF.
Instead of digging up three sections of road to get to the vault and tie into the feeder another maintenance person wants to switch the lighing over to 208V, reason being we can get easily to another pole and feed it from a building with out any road work, problem is 277 is not available from this location, we only have 480V 4 wire or 120/208 in that building. I realize we can put in a delta/wye tranny but I am running into resistance due to the amount of money to install a panel and tranny. There is going to be some road work done next year and we can at that time install a new section of conduit to the orignally fed light.
Now, when I did the voltage drop calculation it was way over code requirements at 208V close to 11 percent and at 277 just around 4-5 percent. Our voltage does tend to run a bit high but even if we have 230 actual volts I still would much rather use the 277. If my boss decides to do this on the 208 volts and we are putting say 180V at the furthest part of the circuit due to drop what issues could we run into if any. The drivers for the led is rated from 120-277V and we would not be overloading the circuit at least not by my calculations (approx 17 amps at 208V).
It is going to get done how my boss decides as I am not on the job definitly but if we are going to have issues that cost more than the tranny and panel then it may get done the way I think it correct.
Hope this makes sense.
Thanks
Thanks
