gar
- Ann Arbor, Michigan
- EE
210220-1551 EST
Fred B:
You need some basic understanding on motor theory.
If you have two different sources of magnetic fields, then where these fields interact there is a force developed between the two field sources. Depending on field polarity the force is either attractive, or repulsive.
In a DC permanent magnetic field motor with a wound rotor and commutator, there is a magnetic force that pushes the rotor away from its position (rotation) by current and its magnetic field in the rotor wire. Because of the brushes and the commutator (a switch) the first rotor wire has current removed, and another rotor wire is connected producing another push in the same direction. So the rotor builds up speed in one direction to some steady level.
Now go to an AC motor. For simplicity make the rotor a permanent magnetic.
First, assume there is one stator winding (coil of wire) fed from an AC voltage. The magnetic field from this coil will oscillate plus and minus some equal amount, and the rotor will not rotate. It may slightly oscillate in one nominal position.
Based on the frequency of the voltage there will be points in time, equally spaced, where the stator magnetic field will be positive. Rotating masses have inertia. So once a mass is started it wants to keep going. So start the mass rotating at synchronous speed to the AC voltage, then apply the AC voltage to the coil in the correct phase relationship, and you will pulse energy into the rotating mass keeping it going at synchronous speed. Now we have a single phase motor running at a speed.
Second, an AC induction motor is essentially the same, except it has rotor slip.
What we don't have is a self starting rotating motor. This is because the AC magnetic field is just oscillating up, down, and reverse.
Third, add a second stator coil positioned 90 degrees from the first coil in space. To this apply a voltage that is 90 degrees shifted in phase from the phase of the first coil. Excite both coils. Now we have a magnetic vector in space that rotates thru 360 degrees. Put a permanent magnet in that rotating field, and that magnet will rotate in space in sync with the rotating magnetic vector. Now you have a self starting motor.
A 3 phase motor simply adds another coil and you make the phase differences 120 degrees.
In the 2 phase motor you could not use 180 degrees because the two phases are in line with each other. So no rotating vector in space.
A single phase motor to be self starting must include some way to get a second magnetic vector shifted in space and electrical timing that is turned on for starting. Usually because of the way it is generated it will draw a high current and needs to be turned off when speed is reached, means a switch. A pure single phase motor will never be self starting.
There is insufficient information on your motor to know how it works. Going from one voltage level to another by itself is not going to produce a single phase motor vs a three phase motor.
There are possibly ways for you to test the motor, and determine how it actually works. But you need a fundamental understanding of motor theory.
Fred B:
