Chase Nipple
jbolen
I have metal box with 3/4 chase nipple between box and 3/4 lb. Does it require a lock nut also.....section please
As long as it makes up tight I don't think it is an issue. Nec uses the term conduit fitting not chase nipple. The white book appears to allow it as long as it is made up tight.
A box with a threaded hub with a chase nipple going into a threaded lb does not require lock nuts. Since the NEC is permissive, there would have to be a code section requiring lock nuts with threaded connections, and there isn't.
A chase nipple between panels or non threaded boxes requires lock nuts, although I do not have a code section at the ready for it.
I agree but I am pretty sure he will have threads on the 3/4" LB. :D
Chase nipple have straight threads and are not permitted in threaded LB's. Yes I know done every day. The correct installation is a close nipple with two locknuts.
How do you use a chase with a box hub and lb? Byclose yes, threads on both ends, chase has built in locknutish
I don't think that the OP mentioned a hub. I'm thinking that he has a 3/4" KO in a box with a chase nipple going into the treads on an LB conduit body.
