circuit board beginner
old8s
image.php
ok this is out of an xbox 360 force fed steering wheel
the fuse was blown so i solderd red and back wires to it to hook up a slow blow 2amp fuse
problem is that L1 is cooked and fuses blow as L1 is getting red hot
what is this ciruit ? im not shre what its doing
the power supply pack is 24v 1.0a and im thinking its 24vac but it only says
24v
i think curcit is 24vac to 24vdc rectifier but might be 24vdc to 12vdc
the steering wheel needs to run a eletric motor
in pos trace goes to f1 to d1 striped side then runds to f1 { c6 bridges f1
in neg trace goes to d1 then runs to f1 { c6 bridges f1
f1 has 4 leggs 2 @ the top where these traces run to and c6 bridges
and 2 @ bottem
from the bottem f1 neg goes to power out but has c5 conected to d2
from the bottem f1 pos is conected to d2 and d2 striped end is power out
what is this curcit for what dose it do can i build a new one
all parts have markings numbers except for f1 is f1 a coil
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC? Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
