Circuit breaker issue - please save me
timlisa20
New member
Texas
Newbie here, and I am hoping someone can help or point me in the right direction. I am so confused and frustrated with this issue I am having. This specific task I did is something I have done several times over the years. By no means am I even close to an expert when it comes to electricity/wires/breakers... Anyway I recently moved in to a new place. The hot water in the house started to run out extremely fast and just didn't seem to be performing well. After investigating I saw that it was the original hot water heater and this house was built in 2006 (so approx. 12-13 years old). The anode rod (AKA "sacrificial rod") had never been replaced. The water in this area is not great and fairly hard. So I wanted to do the basic maintenance of replacing the anode rod and both heating elements. I looked up the model number info so I could get OEM replacement parts. The instructions said to turn off the power to the hot water heater. I found the outside breaker box/panel, and it was already properly labeled H/W heater. The breaker is a Cutler-Hammer 2-pole circuit breaker (not sure that matters). Anyway I clicked it over to the "off" position, went back inside and verified with a multi-meter that it was safe to do my work. After draining the H/W heater and swapping out both heating elements, refill the tank, I went back outside and clicked the circuit breaker back to "on"....here is where all the confusion and frustration starts to happen. Almost immediately the breaker clicks back over to "off" position. I try it once more just in case but with the same result. I could only assume I messed something up on one or both of the heating elements, but there are only two wires and two places they go. I read that the wires can go on either screw on the elements. I tried switching just in case, again same results. I wanted to try and isolate the issue. I disconnected one heating element to see if it was the culprit, same result. I disconnected both heating elements, same result. I started thinking maybe it was just bad luck or timing and that maybe one of the thermostats went out.... I went to GOOGLE and found recommended test for continuity for each thermostat and both showed good. At the top of the hot water heater I saw where the romex wire was tied in. I figured I would start at the source, I disconnected all three wires. I thought with them all disconnected and separated not touching anything that there should not be a "load" and that I could click the breaker back to "on" and go from there, but I be damned if the breaker didn't click back over to "off". So now I put myself in a bad position. I took a hot water heater that may not of been producing the best hot water but now I have it producing no hot water. I am taking off work because we still have 2 days in this week and if my wife does not get to take a warm shower, well lets just say that won't end well for me...Please tell me what I can do, try or something... Any recommendations. I can take any pictures you think will help. Thanks in advance.
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
