hustler
New member
- san diego, ca
Just curious, the ac unit shows a minimum circuit of 31 amps required. The home has a 30 amp circuit breaker to the unit, and the breaker trips often when the unit is running.
I assume the issue is the size of the circuit breaker - that it should probably be a 40 amp breaker, correct?
Any advice would be appreciated.
Thanks!
Thanks!
