Hi,
I would appreciate any input that anyone has on my question. At the company I work at we have a piece of a equipement that draws 300-400 amps from a 3 phase 480 volt input. The piece of equipment is used to test regulators that are produced on-site.
Here is my dilemma. There is a 480 volt circuit breaker (not a building breaker) that was being used to turn on a piece of regulator test equipment. Occasionally, from what I am told the resistors and sometimes the circuit breakers would spark or explode. This made me very nervous since none of the energizing circuitry is enclosed. I told my superior about this and he got a few other people from a couple different departments involved to determine if this was safe. It turned out that no standard written company procedure was attached to using this test equipment. Somewhere someone dropped the ball. One of the older engineers then told us we should be using the house breaker to energize and deenergize the circuit so that we don't have to be close to the energizing circuit when we turn it on and hence not near by it if it explodes.
One of my fellow employees would like to build an enclosed case around the energizing circuitry as well as setting it up so we are flipping a 24 volt switch to turn on the test equipment instead of using the building breaker.
So, my question basically stems out of fear as to what happens when the building breaker fails. Is it safe to be using the building breaker to turn on and off a piece of equipment that draws quite a bit of current? Do building breakers fail from use? How much protection is lost if any by using the building breaker as an on-off switch? Is there anything that I can use in the NEC or elsewhere to support my case if this indeed is an unsafe way of turning something on and off?
This is my first real job out of college. I have a degree in electrical engineering and this is my first real job out of school. This whole ordeal has introduced me to office politics 101. I am interested in what anybody has to say (safe or unsafe) and if they know of anything I can use to back up my case because I am kind of green and no one will listen to what I have to say unless it is solidly supported.
Thanks.
Doug Millner
Thanks.
Doug Millner
