Why are the covers put on before the painting is done?One risk with putting the label on the cover plate is when the painters come and take off all the plates. They don't always all go back onto the same box, so things are now labeled wrong. No label is better than a wrong label.
Re-painting.Why are the covers put on before the painting is done?
My bad. I was in new construction mode.Re-painting.
It would be whatever the specs say.
Just realize that individual labels on every device plate costs money. You have to weigh the value of that information against what it will cost the client. In most cases it not worth the extra cost. A good as-built drawing may be a more cost effective solution.Well right now, we have it specified/detailed as a label on the outside, but I am looking to change things.
I don't disagree. I have heard it done both ways. Some like it on the inside so the faceplate looks clean. it would be more for the repair tech and not the client.Doesn't do the customer/client/tenant much good if the label isn't visible (without removing the cover).
When you ask for opinions, that's what you get!This post didn't go the way I thought it would, but it was helpful non the less
Been there, done that!One risk with putting the label on the cover plate is when the painters come and take off all the plates. They don't always all go back onto the same box, so things are now labeled wrong. No label is better than a wrong label.
I see you never painted a room before! Unless every receptacle in a room is on the same circuit, as the painters just pile them up in a corner and paint. Or, just paint over the cover plates!Not sure I buy the painters shuffling them around theory.
As I said I've just not found this to be much of a problem. Long time between repaintings, and then the space is usually remodeled or has other electrical work anyway. YMMVI see you never painted a room before! Unless every receptacle in a room is on the same circuit, as the painters just pile them up in a corner and paint. Or, just paint over the cover plates!
Marking every mask with what was on a cover plate is just not in the painter's contract! Besides, doesn't the mask get painted over? Isn't that the purpose of masking? Start the sprayer!
