jischr
- St. Louis, MO, USA
I'm in safety and have a couple electrical questions.
Q1 ? Two UL approved portable space heaters, each rated 1500W, are on one power strip. The two users only use them on ?low? because it has tripped the power strip when they both use them at higher settings. It could still be fire hazard if the power strip failed closed and additional load is put on the circuit, at least until the supply breaker tripped. Is administrative control acceptable to the electrical code or is a known potential overload unacceptable?
Q2 ? a 480V cabinet and 120/208V power distribution panel that are properly grounded is subject to water from a leak on the floor above. The enclosures are not rated for wash down. Water is coming out under the room access door. Presuming the circuits are properly grounded there is no risk of shock when touching other metal parts, e.g. the door, or even the enclosures while standing in the water correct? This is to respond to a question from one of the people who walked through water and was too busy to notify anyone of the leak.
Thanks in advance,
John
Thanks in advance,
John
