circuit tracer
a-1 elec
can anyone recomend a good circuit tracer? i have used the 3m tk3 unit fo4r years. they have discontinued it.i tried the greenlee one but have gotten false readings on breakers. any thoughts thanks guys. :eek:
Re: circuit tracer
You can make one that works as well as the tracers. Get a flasher element for a lamp socket, and a 150 watt lamp, HD teflon coated type. Assemble the flasher button and lamp into a pigtail socket, and wire the leads to a male 2 prong cord cap.
Plug the tester in. Shortly the lamp will begin to flash, use an ampprobe at the panel the find the circuit with the varying load.
Re: circuit tracer
Just short the hot conductor to the box and go see what tripped...
Kidding of course, Tom that's a great idea btw, it's never occurred to me. I find the Greenlee tracer I use a bit ambiguous back at the panel, will give your flasher unit a try.
Re: circuit tracer
It gets a lot more definitive when its given a slow calibration pass over all the breakers in the panel first. Its also a lot more effective with the cover off and running the probe along lug end of the breakers where the wire is screwed down.
Re: circuit tracer
thanks guys for the help. im looking for something where you dont have to pull the panel covers off.
