Ckt for a heater
nickelec
US
How do you guys interpret this ckt
To me it's #8 on a 55a breaker
15a for motor +40a for heater
Sent from my SM-G965U using Tapatalk
I think you need two branch circuits. One a 15A and the other a 40A. You can make this a feeder out to the equipment and than create two branch circuits by supplying two OCPD near the equipment .
I think the feeder OCPD would need to be in accordance with 430.63.
I think the feeder conductors need to be #8.
I see it requiring (2) overcurrent devices/circuits to the equipment itself.
It could be possible I have to double-check I only remember seeing one spot for terminations
Even if it did need to feeds could I supply it with one and then put two ocpd at the unit
Sure
Your feeder size would be dependent on the type cable and termination limitations ie: Romex 60°
Looks like two circuits there's that 2nd block on the bottom left there did not notice it before
I'm using fmc (greenfeild) and thhn the problem is I priced and speced the job for a unit
Then when they arrived the unit was completely different so now I'm trying to utilize the existing conduit I already ran and just adding one more as opposed to completely redoing it.
So if I can I would like to run a feeder rated at 55 amps into a junction box and from that junction box tap to disconnects one rated for 40 and one rated for 15
I'm confused, it says an MCA and a MaxOCPD why would this be anything more than a single 40 amp circuit?
Many of the AC units I see have a nameplate that covers mutli-circuit or and/or single circuit.
I agree this looks like the same thing but I don't see a "single circuit" rating.
may just be me :)
It's no different than an AC unit.
No, but I agree with Augie, many units have both single and combined circuit ratings/markings, this one seems to have single circuit ratings only. Why, IDK?
Units with combined circuit ratings often have internal overcurrent protection for each sub-circuit though.
May be listing requirements thing?
If it can be on one single circuit I see no reason it needs to have any more than 37.0 amps minimum conductor ampacity and 40 amp overcurrent device. If it can not be on one circuit a feeder of 37.0 and 40 amp overcurrent to a nearby subpanel would still be acceptable and then run the two required circuits from that.
Then when they arrived the unit was completely different (wish I had a $$ for every time that happened)so now I'm trying to utilize the existing conduit I already ran and just adding one more as opposed to completely redoing it.
I see no problem with that
