How do you guys interpret this ckt
To me it's #8 on a 55a breaker
15a for motor +40a for heater
Sent from my SM-G965U using Tapatalk
Even if it did need to feeds could I supply it with one and then put two ocpd at the unit
I'm confused, it says an MCA and a MaxOCPD why would this be anything more than a single 40 amp circuit?
Looks to me like it gives MCA and MOCP for the heat and for the motor (separately)
No, but I agree with Augie, many units have both single and combined circuit ratings/markings, this one seems to have single circuit ratings only. Why, IDK?It's no different than an AC unit.
I'm using fmc (greenfeild) and thhn the problem is I priced and speced the job for a unit
Then when they arrived the unit was completely different (wish I had a $$ for every time that happened)so now I'm trying to utilize the existing conduit I already ran and just adding one more as opposed to completely redoing it.
So if I can I would like to run a feeder rated at 55 amps into a junction box and from that junction box tap to disconnects one rated for 40 and one rated for 15
Nothing wrong with feeder taps either, feeder only needs to be 40 amps in this case.I see no problem with that
