PaPa D 13
New User
- Pocatello, Idaho
- Journeyman Electrician
I am installing a ventilation fan through the exterior wall of a class 1 division 1 room used to compress methane gas for supplying fuel for our generators. The ventilation fan would be mounted on the exterior wall of the room and operated by a switch located outside the building. I am sure this area would now be a classified area but I can not find it in the code. I have three questions.
1) Would this area around the fan now be a classified area? Please direct me to the proper code or codes.
2) I can install a supply fan drawing fresh air in to the room or I can install an exhaust fan pulling the air from the room. Will both options fall under the same code or will the supply fan fall under a different code or exception since It will be pressurizing the room? Since the fan will not be running continuously I believe it will not make a difference.
3) What if the motor was located outside of the airflow of the fan?
Thank you in advance for your he. Please provide all code references.
