First time I'm on here, so pardon me if my question is not in the correct place.
I have some projects all being built by the same outfit all across New York, as well as some sites in WI and SD, and at each site they are installing a Sewerin gas analyzer that takes in a sample of gas before and then again after H2S scrubbers. The gas analyzer itself is mounted inside of a weatherproof box as it is an outdoor operation. The box itself was mounted a few feet outside of a C1 D2 area, so no problem there, however, the tubing feeds a gas sample (minute) into the analyzer inside of the cabinet. The tubing is plastic. While the gas stream is very insignificant in volume and pressure, being in an enclosed box, the potential for build up exists. And also within that cabinet are breakers and in one of them an outlet. It almost seems to me they are creating a C1D2 area within the cabinet. Thoughts? And yes, I do have good 3 D classified area drawings. Where this cabinet is located is clearly outside of those zones, but the component itself (Sewerin Gas Analyzer Cabinet) is not represented on the drawing.
Picture attached. The yellow lines are plastic gas sample tubes. Methane content is about 54% on the inlet sample and 90% on the outlet sample.
SORRY - COULDN'T GET PIC ATTACHED.
