JoeMarsh
- Anderson,Indiana
Hey Guys! I have an issue I found your forum-what a great place!
I am making an LED light for C1D2 and C2D1 locations. Its an LED light- I have it all figured out but I am running into trouble sealing the light between the PTFE gasket and my glass lens! I am getting an "Air" leak! I set up my own test to try and see if I could apply pressure to the seal to check for an accurate fit. I have a FLAT joint where the edge of my housing, has the PTFE gasket held against it, then the Glass lens is sitting on top of the PTFE gasket. I have a SS metal support ring that mounts it directly to my fixture housing. I can not get the light to "pressurize"(hold 1 psi) using a regulator to set the flow...
I am wondering if there is a liquid or a tape that meets UL 844 or UL 1203 that I can use to seal or at least add to the leak locations to try and stop the leak?
Thanks in Advance for your help!! Joe
