I am located in a chemical plant and we have been question on the need for conduit drains. We have cable trays that run through our process which is rated Class 1 Divison 2 and we come off the tray with rigid conduit. Usually at the low point we will install a conduit tee fitting and the bottom of the Tee we leave open. We have found that the drains made for this application plug up and dont do what they are supposed to do. We do this installation on a couple different applications. We do this on 480 volt motors, and the 120 volt controls. All the cables are tray rated 600 volt insulation and do not get stripped out until the connection box. We also do the same conduit install on our non incendive wiring. My question is, is it acceptable to leave the conduit fittings open to drain? Or by code do we have to install the UL drain in the conduit fitting. Only if the cables are spliced or stripped out do we install the conduit drain into the fitting. Thanks.
