HazInspector
- NZ
Good Day to all.
I have a client locally that is a manufacturer of machines for Class II locations and normally the machine build is in accordance with European standards, specifically IEC. The zones are generated by the machine and the equipment and installation currently is suitable for the zones generated. I have provided compliance consultation and inspection for local and European builds for them.
The question I have is this; my client has secured an order for two machines to be located in the US and in the past the hazardous areas due to combustible dust have never been part of the scope of supply for them. Because they have done a lot of engineering to allow their machines to be compliant in Zone 21 and Zone 22 (for local and European markets), they want to know if a machine complying with IEC standards for equipment and installation will be able to be accepted under your NEC.
Is there some allowance under you rules for an equal or better level of safety to be accepted?
One of the main issues they have is that the machine is automated and high speed so some of the equipment needed with UL approvals will be difficult to source, plus there would need to be major changes to the way the wiring was installed to meet NEC requirements I assume?
Any information on these matters is appreciated, thanks in advance.
