We have a dedicated 120/240V distribution panel located inside an analyzer cabinet 5' wide x 6'-6" tall x 3' deep. The AHJ requires a minimum of 36" of clear work space in front of the panel. Ref NEC 110-26. The code clearances apply to equipment "likely to require examination, adjustment, servicing or maintenance while energized. The panel board is dedicated to this cabinet. No branch circuit exit tthe panel board. Examination, adjustment, servicing or maintenance while energized is not likely to be required and when required, will be performed with the panel board de-energized. Can anyone provide some insight?
