I am not an Electrician but my job requires me to have a basic working knowledge.
My facility is fed by 480 3Ph, 600 Amp service. One of the 480v 200Amp circuits is to a stepdown transformer to 208 3Ph, which feeds a 208 Panel.
A 100Amp panel is one of the feeds off this 208 load center. The 100A main breaker is 3 pole. One of the loads on this panel is an airconditioning unit that is fed off a 2 pole breaker 60A. All the panel breakers are marked 120/240.
Is the airconditioner 1Ph or 3Ph? In other words if you use 2 legs from a 208 3 Ph panel is this now 1 Ph?
