I got called to a job to remove some receptacles that were installed in two walls that is going to become an X-ray room .
Eliminating the devices and just making them junctions is acceptable to the AHJ but the problem I face is properly covering the openings.
The GC is going to install lead lined Sheetrock over the existing standard Sheetrock and I need to blank the openings and provide the same degree of protection.
Would a blank metallic cover with a piece of self adhesive lead of the equivalent thickness on the back side suffice?
Totally removing the boxes and rerouting the cables would be quite involved with the way they feed from several locations.
Thanks
Thanks
