UL CO Detector
UL CO Detector
UL Does not have a standard for CO detectors with the alarm setting your looking for. When UL came out with their standard it raised a big stink among many CO detector manufacturers. The UL standard requires the detector to alarm at 100ppm or 70ppm if the sensor has sat at 70ppm for more than 1 hour.
The excuse given by UL and those opposed to the ability to have a set point at 50ppm, what the the cost to manufacture the solid state, or electrochemical sensor was cost prohibitive.
The reality is that the UL standard is limited to residential applications not commercial where OSHA starts to raise it's head. The requirement for 50ppm is an OSHA requirement.
You can purchase a Macurco (
http://www.macurco.com) sensor that is UL listed and by cutting a jumper you'll get the required Alarm at 50ppm, but you've now voided the listing. Don't sweat that because as I said, UL doesn't have a standard for one of these detectors. Give them a call and they'll talk you through what you need to do.
You'll pay more for this detector but it's a better solution that the UL version. I deal with gas detectors all the time, primarily the Industrial type, at a minimum cost of $1,000.00 or better. I've got one of the Macurco sensors in my attic for my water heater and I'd never put a UL listed unit in...they're worthless.
