- Massachusetts
Jim W in Tampa said:How about a pole on is it safer without or with
That would prove absolutly nothing.
The Amish never get hurt with it not having one.
And that is just stupid:roll:
Jim W in Tampa said:fair enough but what would the time frame be to get it and does it cost anything.
Would hope they disclose this at sale too.They are assuming a lot of liability in doing this.Should a guest get hurt they cant go back on the city,county or EC.I can see where in a huge kitchen with lots of counter space them not needing this space.jim dungar said:I have seen them issued in a matter of days; but you know the faster you need it, the longer it takes. I don't know about costs. The owner, not just the permit holder, must be a participant in the filing process as well as sign the variance application, which means they are acknowledging their acceptance of the risk associated with the variance.
What is then ?mpd said:IMO a variance would not apply here, I cannot grant someone a variance that would allow less than the required minimum or delete code sections, that is not the purpose of a variation
Jim W in Tampa said:What is then ?
Wouldn't that make it a glass rug?SEO said:Has anybody ever seen a glass island on a marble floor?
iwire said:Can anyone provide any proof that installing a receptacle on an island is more dangerous then not installing it?.....
I thought not.:smile:
2-194 Log #1748 NEC-P02 Final Action: Reject
(210.52(C)(2))
____________________________________________________________
Submitter: Ronald Martin, Martha Martin, Citizens Input
Recommendation: Revise as follows:
In private residences the homeowner may elect not to install receptacles in
the center island if the following conditions are met.
● A minimum of 12 linier feet of countertop that is not part of the center
island (need not be continuous).
● The above countertop shall be within 4 ft of the island.
● Homeowner makes provisions for future installation of receptacles in
center island by installing a junction box within the island cabinet for that
purpose.
Substantiation: Receptacles installed on center islands pose a safety hazard
whereas appliances have been knocked down due to the cord being snagged
by people passing close by in crowded conditions. In addition, a toddler just
learning to walk could grab hold of the cord, lose their balance, and pull the
appliance down on top of them. This in fact did happen in our old home.
Receptacles installed on center islands where the sink divides the center
island and there is 12 in. or more counter top between the sink and the edge of
counter top also poses a safety hazard as small slow cookers fit nicely in that
space and could be knocked into the sink or on the floor.
If adequate adjacent counter space and receptacles are provided, there is no
reason to place receptacles in the island.
Furthermore, fine cabinetry with drawers and raised panel doors make
installation and aesthetics less than satisfactory.
Summary
I believe the function of the NEC should be to protect people from hazards
that they may not be aware of. Having receptacles in a center island may
produce more hazards than they eliminate. There needs to be room for choices.
Our personal freedoms are continuously being eroded. Government regulations
are making attempts to idiot proof our lives. Citizens need to be responsible
for their own actions concerning safety in their homes. I believe that common
sense should prevail over bureaucracy mandates.
We spent a lot of money designing our kitchen and made provisions for
plenty of receptacles and do not want them in our center island. Please consider
this change for future requests so that others don?t have to go through what we
are going through. Thank you for considering these changes.
Panel Meeting Action: Reject
Panel Statement: The panel has debated the issue of where to mount
receptacles on islands over numerous code cycles. The current wording of the
NEC provides a reasonable set of rules to address practical mounting based on
the construction of the countertop and cabinets.
Number Eligible to Vote: 12
Ballot Results: Affirmative: 12
electricmanscott said:Things would probably be alot easier if the trade was not dumbed down to the point where we need a book to walk us through every little thing because are too stupid to make a decision based on common sense, right Roger.
Boy would I love to spend some time with some of you guys out in the field.![]()
Jim W in Tampa said:I only know of one way to get out this.Simply tell them not to bolt the island down to the floor.If need be call it something else or store it in the garage till after the CO.The inspector is off the hook and so are you if its not there.Personally i think they are a hazard but nec makes the rules.Just where do we think we are ?America ? Hi Hitler.
From the above ROP
M. D. said:Not proof perhaps,.. but it has been mentioned in this thread that some one's sister pulled a cord and got disfigured (scarred) ,..
HO grabs extension cord and plugs pot into receptacle that makes it so the cord drapes across the walkway. Toddler in walker happens by and grabs cord, pulling boiling hot coffee down on him or her.
BTW, my sister, age two at the time, was burned by hot coffee in such a manner in 1962 and still has scars from her feet to her waist to prove it.
electricmanscott said:Jim, which side are you on today?
