Code Question Regarding Extending A GFCI Circuit With A 5 Foot Section of FMC
BFenton46
New member
Kankakee, IL
Hey, all! New to the forum. Thank you for having me. My city (Kankakee, IL) follows 2005 NEC (just FYI). Need some advice today, please. The main GFCI circuit for my shop in my unfinished basement is in 1/2 EMT, with all TR 3 prong outlets wired off the LOAD side of that circuit's self-grounding GFCI (all downstream outlets are GFCI protected, as a result). I used new 12 gauge THHN wire with 2 conductors There is no ground wire on this 20 amp circuit. In my furnace room (6 feet from the entry way to my main shop area, and the wall is between my furnace room and my main shop area), I added a double gang (stud mounted) electrical box for 2 duplex receptacles. I spliced the 2 wire system from a junction box for the earlier mentioned main shop GFCI circuit, and ran a 4 foot length of Flexible Metal Conduit, and made my connections. Does this violate NEC 250.130C even if I used a length of FMC less than 6 feet? I had not planned on extending my original circuit when I wired it last year, otherwise I would have ran a ground then. I really like this addition of GFCI receptacles, but not if I am in breach of NEC. Please advise and I hope I explained this all well. B
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
