Code reference for conductors not concealed within ballast cover or belly pan.
Joni13308
Denver, Co
EPC Superintendent, Journeyman Electrician
Hello All,
I had a subcontractor performing a lighting retrofit for us. Long story short they are now longer working with us. I am compiling all of their code violations. We had a 2x2 parabolic troffer fixture that was retrofitted, the contractor removed the ballast tray and threw it away. The parabolic lense has ~6"x6" open grates. I have been looking for a code reference for conductors being left open and exposed to unqualified personnel. I have found a couple of references that might incorporate this but I wanted to get some outside opinions. TIA
That type of requirement is typically found in the product standards and not in the NEC.
410.6 requires that the retofit kits be listed and that would also require compliance with the instructions provided for the kit. What do they say?
The NEC does not specifically reference ballast covers. The NEC does require in the luminaire Art (410?) that luminaires be listed, and section 110.3 B requires products to be used per their listing and labeling instructions.
Others may have more comments
