J jamdeck@fuse.net Member Mar 14, 2007 #1 Hello, Is there a minimum distance that conduit must be away from sprinkler heads? J. Deck
iwire Moderator Staff member Location Massachusetts Mar 15, 2007 #2 Not in the NEC. There may be something in a sprinkler code.
J jamdeck@fuse.net Member Mar 15, 2007 #3 Thank you for your answer Thank you for your answer Thank you for your answer.
