Recently I upgraded a panel to 200amps. I called the city planner ahead of time with a question concerning the cold water bond to panel. The house sits on a cement slab, so there is no way of bonding the cold water main to the panel. I asked if I could drive in a ground rod at the panel to bond the panel, and a seperate ground rod at the water main to bond the cold water pipe. Also I said I would bond the cold and hot water to the gas at the hot water heater. He said all sounded good, and I should have no problem. The inspector, however wants the cold water bonded to the panel. There are no water bibs near the panel. Does anybody have a suggestion or more importantly a code reference? Manny Free.
