Cold water pipe bonding
brian
Pennsylvania
The existing cold water pipe to the house is plastic The service is grounded to building steel sized to the conductors and a ground rod #6 When i bond the cold water pipe do I need to run back to the meter location 5' of entrance or just jump the meter and hit the cold water at the nearest location of the service
earlydean
Re: Cold water pipe bonding
What do you intend to bond at the UG water pipe, plastic? If the inside piping is copper, then you may bond them (hot and cold if they aren't sweated together) at any accessible point.
Earl
