color codes
Re: color codes
Bob,
The panel's reason is that white and gray may look too much alike after some time has passed.
Don
Re: color codes
that is very true don i did see it few spots where the white and grey look very simuair color over the time.
i useally take a voltmeter and test to verify it correct voltage because some case i never trust the netural will end up with wrong spot.
is there a way use something like white wire with red stripe on it ?? it will be nice to quickly indetifty the netural at 150 and above volts.
merci, marc
