macmikeman
- Planet macmikeman
If an inspector whines about green tape on a grounding conductor, I'm standing right next to him with my knife in hand........ Whoosh.... insulation gone...........
The issue there is that removed wire from an insulated conductor doesn't automatically become a listed bare wire. It is common that the insulated wire has finer strands than the bare wire of the same size, and depends on the insulation to keep it together.If an inspector whines about green tape on a grounding conductor, I'm standing right next to him with my knife in hand........ Whoosh.... insulation gone...........
You have do it fir the full length of the conductor, not just a the visible ends where the conductor is 6 or smaller.If an inspector whines about green tape on a grounding conductor, I'm standing right next to him with my knife in hand........ Whoosh.... insulation gone...........
might be risky with some of us ole southern inspectors.......... I'm standing right next to him with my knife in hand........ ..........
Further proof that the writers of the codes are just obstinate fellows when it comes down to it.................You have do it fir the full length of the conductor, not just a the visible ends where the conductor is 6 or smaller.
I had one inspector that open carried, he said the city required it “because he was a code enforcement officer”.might be risky with some of us ole southern inspectors![]()
I have always felt if you can't tell that white wire (from a cable assembly) landed on a breaker is an ungrounded conductor, you have no business messing around in the enclosure. Piece of tape isn't going to magically make it any more or less safe.Yet, you can phase tape any size wire if part of a cable assembly and need to reidentify it. I've done it all the time with NM and tray cable. NEC finds crazy things to pick over. Part of why I have lost so much respect for it.
It will when you aren't in the panelboard, and are instead in the enclosure at the other end of the circuit. It helps you identify that the white wire didn't originate at a neutral busbar, but instead originated at a breaker.I have always felt if you can't tell that white wire (from a cable assembly) landed on a breaker is an ungrounded conductor, you have no business messing around in the enclosure. Piece of tape isn't going to magically make it any more or less safe.
To some extent yes. A grounded conductor is still a current carrying conductor and you shouldn't mess with it unless the ungrounded conductors are turned off. Still mostly an attempt at protecting the non qualified IMO. Keep in mind this only applies to a cable assembly - if you understand what it is supplying you still will have a pretty good idea whether it is a grounded or ungrounded conductor most of the time.It will when you aren't in the panelboard, and are instead in the enclosure at the other end of the circuit. It helps you identify that the white wire didn't originate at a neutral busbar, but instead originated at a breaker.
That was the case in one of our jurisdictions some years back. The inspectors still have "police powers" (can write citations, etc) but are not armed.I had one inspector that open carried, he said the city required it “because he was a code enforcement officer”.
I don't know about the electrical inspectors, but in Nassau County NY, the fire inspectors are all armed. Glocks, if I recall.might be risky with some of us ole southern inspectors![]()
Please think of the brother in law's Kwired.I have always felt if you can't tell that white wire (from a cable assembly) landed on a breaker is an ungrounded conductor, you have no business messing around in the enclosure. Piece of tape isn't going to magically make it any more or less safe.
