patsy
- new jersey
is there some wher in the nec that says you have to use certain color wire for specific installations as far as 110v 277v and so on thank you
not really - there are industry standards, and some local codes...
ok i figured ive been looking all over and no find thanx . i had an inspector friday tell me i couldnt use the yellow travler wire because its not 277 its 110v for lights and was used for outlets to
Which is purple in SF, CA.... Instead of orange as it is in the NEC.except of course for the stinger on a highleg
Just do what he wants, and make a mental note about him...ok i figured ive been looking all over and no find thanx . i had an inspector friday tell me i couldnt use the yellow travler wire because its not 277 its 110v for lights and was used for outlets to
if there is only 1 voltage system ON THE PREMISES then you are fine.
You might want to look at 210.5(C) just for future reference.
Yeah - Sometime you have to save the 'good fight' for a 'good fight'. For the most part you cant preach to the converted, or change the mind of the convinced.Just do what he wants, and make a note about him being mental....
thanx augie actually on premis(in the builing) there is 110 and 208 bt the lights and outlets r coming out of the 110v panel. im thinkin its just what this inspector wants.
yes thats correct 120/208
I know someone here can - I would be interested in what it says....Pull out a Code from 1937 through 1975, and you'll find a color code for ungrounded conductors.
