stickboy1375
- Litchfield, CT
JohnJ0906 said:Because that was the answer they required! IMO, it was a reminder to us that it had to be protected.
gotcha... I was just wondering bacause of all the options...
The minimum size copper grounding electrode conductor required to a concrete-encased electrode is...
Where the grounding electrode conductor is connected to a concrete-encased electrode as permitted in 250.52(A)(3), that portion of the conductor that is the sole connection to the grounding electrode shall not be required to be larger than ________ copper wire.
georgestolz said:Edit to add - well, I passed it.![]()
In a dwelling unit, how many receptacle outlets are required on a 4-foot by 8-foot kitchen island with a cooktop installed along the long dimension?
A.) 1
B.) 2
C.) 3
D.) 4
(2) Island Counter Spaces. At least one receptacle shall be installed at each island counter space with a long dimension of 600 mm (24 in.) or greater and a short dimension of 300 mm (12 in.) or greater. Where a rangetop or sink is installed in an island counter and the width of the counter behind the rangetop or sink is less than 300 mm (12 in.), the rangetop or sink is considered to divide the island into two separate countertop spaces as defined in 210.52(C)(4).
