I am wiring my new residential construction. With the expanded requirements for CAF, I have been looking at the HOM dual function breakers. These breakers provide both GFCI and CAF protection at the breaker. Cost wise the combinations are the same as if I use just a CAF breaker. My thought was that I would just use the Dual Function breakers everywhere, thus giving me CAF and GFCI on every circuit.
Here lies the question (I would like to be 2017 compliant).
I typically give every room a circuit, lighting and outlets on one branch.
I typically do the same thing on bathrooms, outlets & lights one branch.
The breakers have a test button, so I would assume that meets requirements for testing the circuits (though it is interesting does it test both CAF and Ground fault ?)
Any problems with this approach ? I have heard people saying not to have GFCI on overhead lights, but I have never seen that be a problem. I have also heard of inspectors not liking bathroom lighting tripping with a ground fault. Personally I think that is preference. If your doing GFCI with an outlet, you can put the light prior to the outlet. The only outlet I don't typically have GFCI coverage on is the fridge outlet in the kitchen.
