If a groundhog could somehow get inside the PVC pipe, he could chew a hundred feet of insulation off of an ungrounded conductor and youd never know the difference.
That is unless he also chewed as small amount insulation off an insulated Equipment Grounding conductor, if it happened to be run with them, and then somehow created a path between them that would allow enough current to travel back through the EGC to the source, where it would have to be bonded to the neutral, to make it trip.
JAP>
JAP>
