CodyMartin2005
- Franklin, Indiana
- Engineer
Hello,
Doing a few replacements in an old commercial kitchens. Because of structure of the building, we cannot come from above or through wall for outlet wire replacement that other work is necessitating. Our plan is to run a 3/4 EMT 90 from the current floor penetration to a rain tight bell box and then use 3/4 EMT to 3 other bell boxes about 4' apart each (each a separate circuit) using THHN wire. (Existing outlets are armor cable running on ground--we'll raise to the 12" inch mark).
The health department dictates "... install all exposed vertical and horizontal service lines one (1) inch away from the walls, ceiling and equipment and six (6) inches above the finished floor. Use approved hangers.". Locally the only EMT hangers I can find are 1/2" from the wall. Does anyone make something deeper or does anyone have an idea on an approved hanger to meet this requirement? Even with a deeper hanger I'd have to use some type of spacer to the boxes. The current trim is all 3/4" PVC which I considered making spacers out of to mount the hangers/boxes on, but want to make sure there isn't' a better solution first.
