R randy640 Member Jun 24, 2010 #1 When is it acceptable to use Romex in an Commercial Meteal building installation?
pete m. Senior Member Location Ohio Jun 24, 2010 #2 You will want to start by reviewing 334.10 and 334.12. I think there you will find the answer. BTW, welcome to the forum. Pete
raider1 Senior Member Staff member Location Logan, Utah Jun 24, 2010 #3 Welcome to the forum. When is it acceptable to use Romex in an Commercial Meteal building installation? Click to expand... When installed in accordance with 334.10(3) and not prohibited by 334.12. Also remember that if the building is an assembly occupancy there are restrictions in those building for the use of NM cable. Chris
W wawireguy Senior Member Jun 24, 2010 #4 You have to know what the building classification is and occupancy along with usage. IE: is it a commercial shop?
J jusme123 Senior Member Location NY Occupation JW Jun 24, 2010 #5 randy640 said: When is it acceptable to use Romex in an Commercial Meteal building installation? Click to expand... for temporary lighting and power
iwire Moderator Staff member Location Massachusetts Jun 24, 2010 #6 jusme123 said: for temporary lighting and power Click to expand... I have wired and worked on many 80,000 to 100,000 sq ft concrete and steel buildings with NM. The only thing that has really put a stop to that was the latest change the prohibited NM above commercial suspended ceilings.
