Can anyone tell me if you can use 4 square boxes with KO's in a commerical kitchen--exposed? Conduit will be emt, are set screw coup. and connectors O.K. or do they need to be compression? What is the code section?
Or do I have to use weatherproof boxes (bell boxes), I know that the outlets need to be GFCI protected-but will that cause a problem on the freezer and frig. also steam table.(tripping gfci)
By the way I can not drop electrical in the wall, has to be exposed.
Thanks for any info in advance.
