common trip
I think this is what you are looking for.
240.15 Ungrounded Conductors.
(A) Overcurrent Device Required. A fuse or an overcurrent trip unit of a circuit breaker shall be connected in series with each ungrounded conductor. A combination of a current transformer and overcurrent relay shall be considered equivalent to an overcurrent trip unit.
FPN: For motor circuits, see Parts III, IV, V, and XI of Article 430.
(B) Circuit Breaker as Overcurrent Device. Circuit breakers shall open all ungrounded conductors of the circuit both manually and automatically unless otherwise permitted in 240.15(B)(1), (B)(2), and (B)(3).
(1) Multiwire Branch Circuit. Except where limited by 210.4(B), individual single-pole circuit breakers, with or without identified handle ties, shall be permitted as the protection for each ungrounded conductor of multiwire branch circuits that serve only single-phase line-to-neutral loads.
(2) Grounded Single-Phase and 3-Wire dc Circuits. In grounded systems, individual single-pole circuit breakers with identified handle ties shall be permitted as the protection for each ungrounded conductor for line-to-line connected loads for single-phase circuits or 3-wire, direct-current circuits.
(3) 3-Phase and 2-Phase Systems. For line-to-line loads in 4-wire, 3-phase systems or 5-wire, 2-phase systems having a grounded neutral point and no conductor operating at a voltage greater than permitted in 210.6, individual single-pole circuit breakers with identified handle ties shall be permitted as the protection for each ungrounded conductor.
Since you said 4-wire I'm assuming that you mean 210.4(B). Common trip, no common disconnect, yes. Can be a common trip CB or single pole CB's with a handle tie.
A key word here is 'feeder'. The response has to do with branch circuits. Comments please.
Rich's response has to do with branch circuit and feeders. The answer is right in the code section he posted. 240.15(B).
common trip
Infinity: 240.15(B) does not require the circuit breaker to open the ungrounded conductors 'simultaneously' thus allowing, for example, a 60a 120/240v 3 wire street lighting feeder to be protected with (2) 60/1 breakers without a handle tie. Comments, please.
If you're asking about a MWBC it is required to disconnect all ungrounded conductors sharing the same neutral. 210.4(B). For a feeder why wouldn't 240.15 apply?
