The increase use in distributed antenna systems inside customer premise locations contains the usage of both coaxial cable and fiber optic cable, as well as twisted pair. This technology involves a multi tranmission format of voice, data, video et all. It seems the majority of the cables used indoors are rated as CM under Article 800, but... because of the use of antennas and analog RF signals in the portion of the architecture, would coaxial cable be considered CATV or communication cable? It seems to me that Article 810 or 820 would no longer apply and the whole DAS system would be classified as strictly Article 800 equipment and that all the cables should be CM rated e.g. CMP, CMR and be tested under UL-910 and UL-444.
Any opinions on this definition of communication or CATV in relation to an indoor DAS system?
