A/A Fuel GTX
- WI & AZ
- Electrician
OK....I give up. Where can I find the definition of a " compact conductor ". Where and when are they used?
It you have used aluminum conductors you have probably worked with compact conductors without noticing it.Originally posted by m73214:
Thanks Guys......I've never seen them used in the field. I'm sure they are more expensive.
Look more closely the next time you use some 4-0 SE cable. The clue is the flattened outer curface of the outermost strands.Originally posted by m73214:
