- Wisconsin
- PE (Retired) - Power Systems
This has nothing to do with European equipment.How would you continue. Please be detailed
Thank You Can you attached a model number. I can't return the unit they ordered it a while back. Why would they make 230 volts Its dual rated at 230 /460 but wired at the 230. Most know 208v are in the buildings. It this more European designed? Like to know why a 230 volt available. Mechanics order this stuff with no knowledge of power available. Motor say 7.5 HP 230volts 20 amps
In the US, we build motors with nameplates showing the voltages they expect to see at their terminals after all of the voltage drop in the building wiring (this is called utilization voltage), while our building power systems use nominal voltages. This gives us motors with 230/460V nameplates intended for use on 240/480V systems.
The two values, 230V and 460V, come from simply being able to connect the motor windings in series or in parallel. It costs more to build a motor that can accept 3 voltages, so most manufacturers don't do it.
208V has been a common voltage for more than 60years, so there is no excuse for people ordering the wrong motors.
