Concealed LV Bluetooth Speaker Power
cewilki
New member
Summerville, SC
I am currently installing a surround sound Bluetooth speaker system with low voltage (24v) supplied to the speakers. In order to conceal the LV wire I would like to run it in the wall and into the back of a 120v outlet. Is there a 120v outlet available with a LV power supply built in (on the backside) available for this type of installation. There are numerous 120v outlets available nowadays with USB ports on the front; I would assume that the desired configuration exist, however I cannot find it. Any reference would be greatly appreciated.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
