Concrete Ceiling
That really doesn't look like poured concrete. It looks more like cinder blocks but we know that can't be the case. LOL
You can actually surface mount a pancake box which will be more shallow than the wiremold box. There also looks like there is plenty of concrete to cut in a pancake box. If the fixture will allow the 1/2" then just surface mount it.
More than likey it's a precast concrete slab.
Although the texture does look like a cinder block
The texture looks like spray-applied texture, and so reveals nothing about the underlying material. You can see the underlying concrete around the threaded inserts.
Cheers, Wayne
Thanks Wayne!
I know it's a slab.
If you look beyond the textured paint it concrete looks kinda of porous.
He could chip it out to recess a box but he'd have to get creative in securing it.
Thanks Wayne!
I know it's a slab.
Its an old 5 story building. This is on the 1st floor above the garage. Anyway.. here's a close up if this helps confirm you guys thoughts. About 1.25" thick
I thought about recessing but might be too risky
I'll have to check depth of screw insert with paper clip or wire. Thanks
What is on the other side of the concrete? Someone else's floor, an accessible concealed space, or a void? I'd use the inserts, but if something gives its nice to know your options should you need to recess the box or drill all the way through.
Theres a small void then the floor for units above
