Concrete encased electrode for residential home?
The tricky part is that that exception that says the CEE doesn't have to be used in "existing buildings or structures" if the concrete makes it inaccessible. So if I pour concrete without remembering to make a connection to the CEE then I have an 'existing structure' with an inaccessible CEE. Grounds rods here we come.
What I've mostly dealt with is inspectors not acknowledging the existence of a CEE unless there's a job card showing it signed off in a special place before the pour. Which is the flip side of requiring it to be done before the pour, let alone requiring extra measures to install a CEE if the pour happens without a proper GEC to CEE installed.
You should summit that Oregon code amendment as worded as a proposed amendment to your local residential building code, its well worded and gives clear guidance for the structural inspector to look for that. Its been in the Oregon code a long time now.
