bjp_ne_elec
- Southern NH
Got a call today - local condo complex has the local utility show up during New Years Eve feastivities and determines the issue isn't on their end. They tell the staggering occupants how to reset the breaker if it goes again. I'm thinking, I wouldn't be giving that advice. First they never mentioned to shut down all the mains on the eight section OCP protected units from the outdoor meter distribution panel. Not a good idea to be turning this on without shutting down most of the load - especially not even knowing why the breaker is even tripping (loose connection, overloaded leg, defective breaker, etc, etc).
Well first of all I get called in and there is no labeling in the enclosure and the only thing I can make out on one of the breakers it "ITE". Call the local ITE distributor to find out he's not even open.
As I'm used to doing mostly new work - but branching in to more and more service work - due to there isn't much new work going on. I've never wired one of these "multi-meter socket/multi-breaker distribution panels (if that's the correct term) so this is all new to me and I'm looking to my friends and fellow ECs and JWs to help me out. This main breaker is in a seperate WP (and I use that term loosely as I found the weatherstrip that runs the perimeter of the inside of the box to be sagged so one corner isn't even fuctioning) enclosure. With this breaker inside - actually has a little extension handle that I found sitting in the bottom of the enclosure. How "safe" is it to pull the cover - it's basically two screws that sit at the bottom, and up top there are just two little tabs where the top of the cover sits behind it to stop the cover from tipping forward. No other screws. I was leary of pulling this as it comes right from the secondary side of a pad mounted transformer.
I'm guessing this thing is probably a 1000A or larger - each unit has a 200A main in this outside distribution set up. I was surprised that no amerage was listed on the handle - but I checked several other units.
Talk to the condo associations local rep and ask if there are any blueprints, drawings - anything that might have some Part Numbers listed or a line diagram of the distribution. I get a blank stare.
So the only way I'm even going to have a shot at finding out more info is to pull the inside cover - and I'm looking to see how safe that is. I'm thinking the face of the breaker behind this metal cover would stop the panel from going inward - but I'm not absolutely sure.
So who out there has worked on an ITE panel of this type and what should I be looking for?
Also, as long as I'm learning, I flipped open the little WP (and I use this loosely as well , as not one of them is latched, so the seal isn't even have a chance to perform the function it was intended for) and oddly find a 4-pole breaker. If someone was looking at me at that exact moment - they would have seen my blank stare. So guys, what's this 4-pole?
Thanks
Thanks
