Two thing come into play, first is the conductor fill ratio of 40% which is never reached and the second and must misunderstood is the derating using the 90deg column of 310.15 which will reduce the allowed amps per conductor. Each conductor had heat placed on it that affects the one next to it and breaks down the insulation. Wire has memory and when it comes off a spool it falls into place which is one of man reason in trench ducts that can be very wide the NEC in 2008 made word changes to each article so it would not be missed as it has over the years. Two things have to happen to increase wires in raceways, one is to have free air space and heat reduction. There is only one patented and tested way this can be done and it is coolWIRE which has been vetted by all bodies from private to government.
