elektrikution
- New York
I've installed 60' of 3/4" emt and then converted to fmc for the last 5' of the run. This run is supplying a 50 amp, 240 volt, 4 wire range. So I pulled 4- #8 thhn copper . So when the range is energized, I can actually hear and slightly feel the wires resonating in the panel. Is this normal? And is the 3/4" emt large enough for those size conductors?
