After installing a 480 volt feeder from a 30 amp fusible disconnect located in an MCC to a 30 amp 3 phase fusible disconnect. I would like to install a junction box with 600 volt terminals on the load side of the field fuse disconnect. And route two cables to 2 Size 1 manual starters for a couple of air handlers with FLA of about 8 amps each.
How do I size the conductors from the J.B. to the manual starters.
